Hello friends,
There is an opera problem with nexus personal. I tried installing nexus personal to Mozilla Firefox and it turned out well. When I tried installing it with Opera browser it crashes and does not get a successful installation. What is the main reason of this problem?
Thanks and Regards,
Kristin Runaldou.
Only the Mozilla Firefox worked since it supports flash on Nexus personal. Two web browsers however aren’t compatible with Nexus Personal which is Google Chrome (beta version) and Opera Browser. These two browsers always crash whenever the flash is used. If you want to use Nexus personal on other browsers, Dolphin HD 8.5x supports it.
Hey Kristin,
Nexus Personal operates using flash, and there for you need a flash plug-in to your Opera Browser.
1. Go to the android market and download Flash Player.
2. Go to your Opera Browser and type opera: plugins in the address bar.
3. If something appears like below, then it worked.
Shockwave Flash.
Description: Shockwave Flash 10.2Â d156
/data/data/com.adobe.flashplayer/lib/libflashplayer.so
4. If nothing appears, make sure plug-ins are enabled, go to settings, advanced, adobe flash, enable.
5. If still nothing appears then your phone version + browser will not be able to run Flash. Choose another browser.
