I use Punch Design Studio Version 17 to design and plan my home and landscaping projects.
Is there an option or preference in Punch Design saving as PDF format for my presentations?
I have a 21.5" iMac with 2.6 GHz Quad Core i5, 8 GB RAM, NVIDIA Geforce GT 640M Graphics processor and OSx Leopard.
Is there an option for Punch Design saving as PDF?
Hello Andrew,
I have seen the documentation of the software, and I have an indirect solution for your problem.
To save the models and designs in the PDF format you need to have an Adobe PDF Professional version or similar software like Foxit Phantom PDF.
Either of this software, will create a PDF printer in your printer folder.
The model or design which you want to convert to PDF, you can just simply go to the File menu of your software and select Print. In the Print page, you need to select the PDF printer and click on Print.
It will ask for the location and the name of the PDF file which has been printed or converted by the PDF printer.
These images, designs and models then can be used in the presentation.
I hope I have answered your question. If you need any further help, please don't hesitate to contact.
Hello, Andrew J Nieves
It's very ease, please visit this site and download doPDF-v7 software.
Then install the doPDF-v7 software in your computer. Then open your document which you convert to PDF format.
Click File Manu > Print Then will be open print dialog box.
Select printer doPDF-v7 then click OK.
Hope you got the answer and can do it
Successfully.
If you have another issue keeps visiting here for further Information.
Have a good time.
