Hi fellow members. Is there a way for Outlook display countdown date? Does Outlook have this feature? I want a daily reminder or countdown until the specified date. I use Microsoft Outlook 2010 on Windows 7 64 bit. Any help would be much appreciated. Thanks in advance.
Is there an Outlook display countdown date?
Hi Dorothy. Â Outlook does not backup structuring calendar items that count down (or a count up) to a specific date. Â You should certainly devise each item one by one. Â The most convenient way to accomplish this is outside of Outlook and import the file to the Calendar. Â You can apply this particular technique with any version of Excel and Outlook, although, some procedures might slightly vary in older editions of either program. Â If in case you have another spreadsheet program, such as works, you might need to save it as a CSV or text file to import into Outlook. Â Hope this information helps.
