I have a Samsung GT-P1000 Galaxy Tab with Android 2.3 (Ginger Bread) and Hummingbird chipset. I'm trying to find WinZip 17 Pro for Android phones. Is there a P 1000 free winzip app for android? Can someone point me in the right direction?Â
There is a neat program for compressing and uncompressing zip and rar files for Android. It is named "Easy Unrar Lite". Not only does it deal properly with zip and rar files but it also helps you explore through the file system on your Android set.
I was searching for such a program as that for myself when I needed to unzip a very large zip file. I found and it did the job just fine. Mine is Samsung Galaxy Y with Android GingerBread on it.
Hope it helps.
Best Regards,
Parisi
WinZip is a cross-platform file archiver that doesn’t only support desktop computers but mobile phones as well. If you have an Android phone, you can download WinZip for Android on the Google Play store. The latest version at the moment is WinZip 4.2.3 released on April 18, 2019 and requires Android 4.0 Ice Cream Sandwich and higher. Another file archiver you can use on Android is 7Zipper.
The latest version at the moment is 7Zipper 3.10.45 released on July 26, 2019 and requires Android 4.0 Ice Cream Sandwich and higher. Though 7Zipper appears to be the Android version of 7-Zip, this app is not officially from Igor Pavlov, the developer of 7-Zip. It is from a different software developer. If your device runs on an earlier Android, these latest versions don’t support your device.
But still visit the links to see if Google Play has an older version compatible with your device.
