Is there a PDF reader for BlackBerry 9000?
Hello friends,
Is there a pdf reader for blackberry 9000? Blackberry mobile phones are one of the most popular brands all over the world, they make the best themes and features for a desirable mobile phone application. Is it possible for a blackberry 9000 unit to handle pdf files?
Thanks and Regards,
Christine Yong.
Best Answer by Frater Dessin
Answered By 0 points N/A #183647
There is a little issue in Blackberry bold 9000 in viewing PDF files. Although there is an inbuilt application to read PDF files within Blackberry there is an issue. The problem is you can read PDF files that you receive through emails, but you can't view PDFs that are stored in your device memory card. You do have two options in order to read PDF files in your Blackberry.
1. You'll have to download an external software which enables you to read PDF files stored in your memory chip. You can do a simple Google search on the keyword "PDF reader for blackberry 9000" and you can choose a software out of the alternatives.
2 You can send the PDF file that you have stored in your memory composed as an email to yourself, and open it in the email reader in your Blackberry device.
Answered By 0 points N/A #183648
Hi Christine Yong,
There is a PDF reader for your Blackberry 9000 where you will download it in your Blackberry App World. You can use the "Documents to Go" App for your device. To install this App, you will have to open the Blackberry App World on your device. You will see this in your Menu page. The Blackberry App World is where you will search and download your apps for your Blackberry device. After launching your BB App World, type on the search engine, "Documents to Go." You may purchase this to be able to download the app.
Hope this helps.
