Please help. I was working on a file in Photoshop when the program suddenly crashed. I could not locate it on the temporary files and I badly need to recover it. Is there a Photoshop CS5 recover temp feature that I can use?
Is there a Photoshop CS5 recover temp feature?
No, it cannot be recovered because there is no auto saving feature in Photoshop CS5. As you didn’t save the file at least once so it no longer exists on your computer.
However, you can avoid this problem in the future by installing this auto saver software which will automatically keep saving Photoshop CS5 files.
Hi Dorethadhoward. Based on what I know, there are no CS5 recovery temp features in Photoshop. But there's a method you can use to solve your problem . Back to Photoshop, File> Open, change the file's extension from .Tmp to .Pad and click open. I hope this information will be beneficial to you.
