Luz M Terry
35 points
Posted on - 06/02/2013
How can I validate my PHP forms? Is there a PHP form validator ide plugin if so for which ide and which plugin? PHP Form Validator 1.0 allows PHP validation so that is another possibility what would be the regular expression that I would use for a phone number using this software?
Is there a php form validator ide Plugin or any suggestions?
Hi Luz M Terry,
Yes, there is a PHP validator that is available on the web. It is very important to have a validator on your website before you take all the necessary information that you needed to request from a user, though you can make web forms with validators with Simfatic forms. I attached here the link of a validator script that is produced in PHP programs. Link:
