Halton Roy
50 points
Posted on - 04/24/2013
Hallo there!
I am running a small network testing project for a client and I am pinging all the time. I wanted to give them more information whenever I carry out the network tests. This I wanted to calculate the speed and the bandwidth during some particular intervals. Is there a ping tool with bandwidth calculator that I can use for this? A good work at this juncture is giving me a better job in the future, so please share with me your best. Thanks.
Is there a ping tool with bandwidth calculator for network analysis?
So Halton, Do you need a Bandwidth calculator that is based on the ping time of your device to another device? Try "Curt's world Calculator" It is a website based calculator that can compute for the available bandwidth between different devices. There's also some explanation on that website that discusses how to use that bandwidth calculator.
Halton you can use many different ways to show the bandwidth usage of your internet. You can use link for speedtest. This will help you test the speed from your location to the location you want to test it.
Another is you can do the following:
1. Windows key + r
2. Type cmd
3. Ping address-that-you-want >logfile.txt
Then you can see the file on the location C:UsersIT.
You can use this and send to clients that you want.
