Is there a PLS viewer in wmp?
Hello fellow members. Is there a PLS viewer in WMP?Â
I was hoping to view internet radio streams on my Windows Media Player.Â
I use Windows Media Player 11 on a Windows XP 64 bit environment.Â
Thanks in advance.
Thanks in advance.
Hello, Eleni.
Here are some ways to open your PLS file using OpenPlsInWM.exe.
First, you need to download OpenPlsInWM.exe
After downloading, save your PLS file to where you want to stock. Then, find your PLS files. Right-click on it,  select "Open with…"
Browse your Open Plsin WMÂ where you save it. Then, check the "Always use the selected program"Â checkbox.
Then press "OK". There you go, you can now try to play it with Windows Media Player. 🙂
I hope this will help you play you PLS file in WMP.
Best regards.Â
Hi!
Yes PLS can play in Windows Media Player the only problem is that WMP doesn't know that this is possible to make.
There is a PLS opener that you need to download and install this is the "OPEN PLS".
This is the program that will open the PLS then send the information to WMP.
