elsietbrown
20 points
Posted on - 05/18/2013
Hi people. I use Windows Media Player mainly for opening my mp3's and mpeg video files. Is there a podcast addon wmp so I can listen to it directly without saving it? I use Windows Media Player 10 on a Windows XP 64 bit system.
Is there a Podcast addon wmp?
Hello there,
Well, one way to fix your issue would be to upgrade your Windows Media Player 10 to a more recent version that supports live streaming like Windows Media Player 11, still compatible with your Windows XP 64 bit system.
Otherwise, if you think Windows Media Player 10 is your one and only, then you should probably try to install an appropriate codec, perhaps the Media Player Codec Pack could be a good choice.
Mcgee Zackery
