Madison
10 points
Posted on - 01/06/2013
There is a problem with the driver print artist 8. When trying to run the print artist 8 software applications in my manager’s computer desktop with Windows 7 Os, the application suddenly pops up and disappears immediately. It never loads from the server. What would be the best solution for this kind of problem?
Madison.
Hello Madison,
I will suggest you some thing that you can try which would hopefully solve your problem.
– Did the software install correctly ? Uninstall the software and install it again.
– There might be a program that is stopping Print Artist 8, Press Windows+R buttons and type msconfig, in the General tab click on Diagnostic Start-up Item, click Ok and then select Restart now, after the computer starts try to run your program.
– Consider upgrading your program.
