There is a problem encoding in acrobat.
Hello experts,
There is a problem encoding in acrobat. My acrobat reader cannot find a way to encode a file or edit a specific file in a pdf format. I hope there is a best way that will let me edit my pdf files which contains 50 pages that needs to be edited. I wish you can give me an accurate answer. Thank you.
Best Answer by RANDOLPH Rosa
Answered By 0 points N/A #178985
Thank you for your question. In order for you to edit a pdf document you require either Adobe standard or Adobe professional.You may not edit a pdf document using Adobe reader.
Answered By 0 points N/A #178986
Hi Chloe Chylly,
 Adobe Reader only allows you to view and print PDF documents. You can create or edit a PDF document with Adobe Acrobat (Standard, Pro, or Pro Extended), or a third-party application such as OpenOffice.org.
