There is a problem with samsung wave 723 reboot.
Hi techyv,
There is a problem with Samsung wave 723 reboot. Every time I tried to open a big application such as games, images and videos my Samsung wave mobile phone will automatically restart or reboot. I have to do something to fix this issue. Is there a way to get rid of the auto reboot problem?
Hoping for your help.
Answered By 0 points N/A #181331
Try to switch off your phone and then charge the battery while it is OFF. While charging, you can see the battery icon on the screen. Try to switch it ON while it's charging. The Bada (Samsung's Smartphone platform) will be loading all the files properly and your phone will now be working as usual. If this doesn't work, try to format all the memory in your phone, there might be some bug file in your memory card. Hope this one works for you.
