Hello experts,
There is a problem in sequel pro crash with Windows Vista. I hope you can give me the main reason why is this happening. Every time I tried to run the application there is always a compatibility error. How will I be going to resolve this issue? I am using Windows Vista operating system.
There is a problem in sequel pro crash with windows vista.
Hello Virginia Adams,
Thanks for sharing your problem with us, according to me Sequel Pro is a Mac database management application for working with MySQL database. It will not work with windows. If you want to use sequel pro then you have to use MacBook having Mac OS*10. 5 or newer as operating system.
You can use the following application as an alternative for the Sequel pro in windows:
1. HeidiSQL
2. Navicat
3. SQLyog
I think this answer will solve your problem.
This problem may occur for compatibility reasons. I think your software is not compatible with windows vista. Try to check what vista version you are using, is your windows 64 bit or 32 bit. You did not mention these facts.
So try to check those facts. After checking those facts if you face the same problem again then tries ask a new question such as I am using windows vista 32 bit and I am facing this problem so what is the solution.
