Hello experts,
There is a problems with pctv pinnacle h264. The octv pinnacle for a h264 format, I think there is a format compatibility issue about this matter. An idea or suggestion in this topic will be much appreciated, cite some possible cause of the problem. Thank you.
Hi Davis,
It looks perfect that pinnacle H264 installed with your PCTV Software and seems that no problem will come but the main issue is that it will use a little bit extra or more CPU. so it makes problem in frame skips or one main problem when frame skips audio sync problem.
I advise you to use DVB Viewer it works good with all channels the big reason, it can use much less CPU then PCTV
One very big genuine issue is that your system is not highly powered, mean to say slow not too highly powered machine.
