Is there a program to do that ?
Hi Techyv Team ,
I am looking way to control windows volume in Windows Vista using shortcut keys. Is there any application or program to control it? I try the program "VolumeTray" that I use with windows XP but it won’t work. Please help me! Thanks!
Answered By 0 points N/A #100184
No can't do, there is no software or any other way to adjust your volume by setting up shortcut keys in Vista. You can either avail this in laptops, notebooks, or netbooks in which some of it but not all, needs the FN button plus a specific key to adjust the volume. There are also some special keyboards that you can buy that has the button control for the volume like HP or Logitech keyboard, mostly branded keyboards but it is to pricey to buy but if you really want it, then I suggest that you buy this so won't even bother thinking of adjusting volume in the system tray.
