Is there a program that Restore Sandisk files?
I have a problem about my memory card.
When I pulled out the memory card in my cell phone, then put it again, the phone says:
"The device is corrupted and need to reformat", but there are lots of very important files that is very needed in my school projects, and I need to restore the photos that I need to use.
The question now is, can I restore the files that I need?
If yes, what should I do?
Should I use computer programs?
Thank you!
Best Answer by John D Armstrong
Answered By 0 points N/A #162437
Download an anti-virus for your cell phone compatible with your cell phone platform if there is any and scan it.
Scan your memory card in the computer through a card reader, it can be affected by the virus.
If it doesn’t work contact with your network service provider that if they have any backup facilities.
Hope your problem will be solved.
Thank you.
Answered By 10 points N/A #162438
Hi there Singculan_dustin,
That situation usually happens when you shut down the drive or disconnect while it is still being used by other devices. Try to open your memory card in another computer or device. But if you still can't open it. Try to use a recovery software. You may try Recuva, a free utility in restoring files.
It's very easy to use and is able to recover files that might have been deleted by bugs, viruses and crashes. It has good features as well. Be wary of some toolbars that came with the software. Download LINK.
Another recovery software you may use is Pandora. Download LINK.
Hope this will help you restore or recover your important files.
Feel free to ask if you have any clarifications.
