Hi guys,
My Skype is showing a message regarding downloading update. The current version of Skype is good.
Does it provide more user interfaces if I update my Skype as per the request?
Please help me to give more information about this update.
Skype – Update
Download a Skype update.
There’s a new version of Skype available. Update now to get the latest features and improvements.
The update will give you more features like Better video and audio quality, Sync with Facebook and Save call and chat history. It will also fix minor bugs that you are experiencing on the previous version of Skype.
Hello Hunter Chasee,
The latest version of Skype is Skype 5.11.0.102 (Beta). You can use it to your Skype service. You can upgrade your Skype version and use it. If any problem occurs you can download your using version from below link: https://www.skype.com/en/.
If you want to know you’re using Skype version follow the step: Menu bar> Help > About Skype.
jkiarr
There is no newer version of Skype, its just an update that will make the version you are using more reliable and simpler to work with. An update changes how a program executes commands. It could make it load faster, add new interfaces as you have stated and so on. Hope you find this statement useful.
mdfahim
If you want you can update your Skype software the old one is good but the latest one is more awesome. Its show everyone. I already update my old Skype. Its good you can update it if you want. Latest Skype is good there is no problem in this update you can do it.its so easy.
