Is there a Samsung Audio Utility for Galaxy Y?
Good Day Everyone!
Anyone please tell me if there’s a Samsung audio utility for Galaxy Y? I am looking for a way to improve the volume of my phone. Can anyone please help me? If you have tried fixing this before then please guide me. Have you used a third party application? Have you used a downloaded utility tool from Samsung? Any information will be helpful.
Thank you so much.
Best Answer by Hoffman Pero
Answered By 0 points N/A #131629
Hi
There are many alternative sources to get audio utilities for Samsung galaxy Y. But let me direct you the easy one just follow or browse this link and get all the audio music you want to get. Of course you need to down load all the music you want to have on your mobile.
Answered By 0 points N/A #131630
Allissarachel
There is a audio utility for samsung galaxy-y check their website at samsung.com
There is a utility of samsung that is what you call wireless audio dock which is the
World's first dual dock sound system.It enhances the music and sound we've loved
To hear. It has a built in vacuum tube amplifier.It tones and balances the sound
Your mobile phone.
Answered By 0 points N/A #131631
Hi, Alissarachel.
I found a solution on Samsung Galaxy Y audio booster.
Actually, android was used Beats Audio Booster to enhance the quality of the Galaxy Y audio and this was proven without any problem even force close or any bugs. And this works very well. But, you need to download it from any of the sites who offered this called "Beats Audio". I'm sure you can find on some websites. What you need to do is just download. After that, put it your SD card and reboot your Galaxy Y phone into android recovery and apply the zip from the menu. And you're done.! Please wait until your phone got turned on.
In manipulating Beats Manager settings, just add the widget Beats Manager and feel free to set time equalizer. Anyway, I got a temporary link to download the apps. Just try to visit this one https://www.dropbox.com/s/udy0qufgspx8bt4/BeatsAudio_ByNimit_signed.zip.
Hope this will help you a lot.
Best regards.
