Is there a sis to nth converter online?
I want a Nokia phone theme to be converted from .sis to .nth format. Is there a sis to nth converter online? Or should I download a software on some sites?
Hello Martin,
Sad to say but I don't think you would be able to find a converter for .nth to .sis format or vice versa anywhere as both format are run from different interface. .nth are themes under nokia S40 while .sis format themes are under nokia S60. I suggest you try to just make your own theme similar to your desired .sis theme or just search online for free .sis themes. Here are couple of sites with terrific nokia themes:
That’s right. It’s not possible to convert a SIS file into NTH. The SIS format is the theme format used in series 60 Nokia handsets and the NTH format is the theme format used for series 40 Nokia handsets. I’ve read a lot of inquiries about this but according to Microsoft community website there is no such tool.
Also, in many different ways it is not possible because the series 40 and the series 60 themes are very different including the theme structures. The only possible way you can convert it is to do it manually by acquiring the original artwork from the series 60 theme and use it as a basis to build a new series 40 theme from scratch.
If you are looking for series 40 themes that you can apply on your Nokia handset, try the following:
