Is there some convert DVD to audio driver needed for copying?
Hello!
I have DVD files here that must be copied to the laptop. However, the problem is that the audio files are not playing well. Is there some convert DVD to audio driver needed for this? It is really not that important for now as my cousin doesn’t need it, but I want to know this in case I want to copy movies of own.
Thanks!
Answered By 10 points N/A #145277
Copying DVD files is different from copying mp3 files as many files need to be copied. As you must be knowing, DVDs have many features. For example, subtitles or menu. Hence DVD files need to be copied altogether for you to play the DVD. This can be a bit tricky. Sometimes you can easily pull out the movie containing files. Otherwise you have to convert the whole DVD to a different format like flv.
To do this you can use a converter. The following links provide lists of converters.
http://www.vso-software.fr/products/dvd-converter/dvd-converter.php
http://www.any-video-converter.com/products/for_dvd/
Hope that helps!
