Is there a surveillance software for webcam?
Hi there.  I have a Logitech HD Pro Webcam C920 High Speed USB 2.0 with Full HD 1080p recording and Carl Zeiss Optics.  I want my webcam to double as a surveillance cam.  Is there a surveillance software for webcam Logitech?  Thanks guys.
Best Answer by Holloway Hively
Answered By 0 points N/A #148057
There are surveillance software’s for webcam Logitech. You can download this software from the https://support.logitech.com/en_us/home website, which also gives you instructions on how to install the software and set everything up until your webcam starts functioning as it should. You can also download the software from a trusted site such as informer.com.
Answered By 5 points N/A #148058
Hi Dudley,
There are several software for your Logitech that you might consider to download. These are:
