Is there an test case online builder tools !!!
Hi everyone,
I'm a developer, I use test case builder tools frequently. I would like to know if there is a test case online builder?
Please it is very urgent!
Thanks !
Hi everyone,
Thanks !
Hi Levine Good,
No. Oracle's products don't offer an online emulator for your test builder. I would suggest that you may keep the software on your computer and use it frequently. You have no choice but Oracle isn't planning to deploy that product over the cloud.
Best of wishes.
Hi Levine,
I'm afraid there's no available online test case builder. What I can suggest for you to do, in order for you to continue is to download and install one of the below the stand-alone application.
Hope this helps you.
Notifications
