Hi
I am offering online jobs to write short articles about the business in our country. I need to check whether they are original or copy paste contents. So is there an unlimited online plagiarism document scan web site?
Thanks
Is there an unlimited online plagiarism document scan web site?
Hello Brother,
You mentioned you are offering online jobs to write short articles about the business in your country. So you need to check whether the workers searching for the information and then typing it with their own hand or just copy and paste contents.
Yes , there is an unlimited online Plagiarism document scan web site. This is:
www.plagiarism-detector.com
Here you can detect whether it is copy paste or original by just uploading the file or pasting the file in the blank space.
Greetings Mr Mariannebford,
There are several unlimited online plagiarism document scan in the web, such as :
1. Copyscape. This tool could search all PDF files, websites, blog, forum, whether the article is published or not. The tool itself is free, but with some limitation. This tool could be the favorite tool if it is used as a premium user.
2. Plagiarisma.net . One the best free duplicate content checker, with 190+ language support, ability to check an uploaded item in pdf/ doc/ docx/ rtf/ odt/ txt/ html type. In addition to Google, this tool can use Babylon and Yahoo indexer also.
3. Duplichecker.com. Another free tool on the web to check an article content with txt type of file. This tool can use Google, MSN, and Yahoo! indexer.
Hope this helps!
Stonjhon Llison
Hi Marianne!
I would recommend that you use Duplichecker. It is an online software for plagiarism detection which provides quality web content to famous websites. It was designed to reveal the full authentication results by checking each sentence carefully from where it came from or if it was really composed of the individual who made it.
You can check the authentication of a document by copying and pasting the URL in the big box that you would see on the homepage and press search for the results. As easy as that. I hope this will help you.
Good luck!
