I purchased the game Toy Soldiers and cracked it with Skidrow. All worked well but when I played the lead soldier, the game just crashed. My PC runs on Xp with Core 2 Duo 2.0 GHz and I recently found out that the game is for Windows 7. Will there be a new crack or update for lead soldier windows 7?
Is there an update for Lead soldier windows 7?
Hello Johnnie M Ehrhardt,
I have read the patch log of Toy Soldiers (1.1) and there is a chance that your issue will not be resolved by the patch so the best you can do is to contact their customer support and tell them your issue. They might be able to help you with your problem. While you wait for the reply, try the following:
– Uninstall the game and reinstall it again. There might be some files that were damaged or partially downloaded.
– If you know someone who has Windows 7 installed, try to install the game from there and see if the problem still occurs.
Write down the problems you encounter when you follow-up on the customer service's reply.
Hope this helps.
