Halton Roy
50 points
Posted on - 06/24/2012
I have been searching for web page builders. I came across the WYSIWYG Web Builder 8 2 1 2. It claims that you do not need to kow any html codes because you just need to drag and drop the layouts you want. Is there another program such as the WYSIWYG web builder that is more updated in terms of web page building?
Is there an updated web page builder that is easy to use?
WYSIWYG (What-You-See-Is-What-You-Get) system utilized to make Web pages. WYSIWYG denotes that the finalized pages will presentation precisely the way it was composed. The system creates HTML tags while you indicate and click on craved methods, you would be able to make a Web page without memorizing HTML.
Offer post No HTML information required. Plain structures creation Add pattern HTML ActiveX, JAVA, Flash, Windows Media player, QuickTime, and different connect-to backing. Produce to nearby drive or a FTP server utilizing the raise-in FTP supervisor. Turning Ad Banners Several travel devices, Go menu, Menu bar, and Navigation bars Shape segment. Here are some other tools you can use,
WeBuilder 2011
Sitoo Web
Dynamic HTML Editor
Adobe Dreamweaver
