Is there a version of CIV2 for x64?
Its been a couple of months since I played Civ2. I tried to load it in my new computer, but cannot make the program run as it is not compatible with 64 bits. Is there a version of CIV2 for x64? Thank you.
For sure there is a 64 bit version of the Civ2 application. All you will need to do is go to Google or your favorite search engine and then search for 'Civ2 64 bit patch'. Among the results that will be displayed, choose the most probable that will give you the option for downloading the setup for that application.
Some of the patches for that application which are from the civilization chronicles can be found at the following site: http://www.thesewall.com/2016/07/19/installing-civilization-ii-on-64-bit-systems/
You will also need to check some other details like the server pack of your operating system for they too may be the reason why the application may refuse to work.
-Experttechyv
