Acke Zimri
50 points
Posted on - 09/18/2012
Hi experts,
Is there a video screen capture software? Because I need it for my upcoming activities and I want a software like that. I am wishing and hoping that you will help me find the best solution. Thanks
There are lot of screen capturing tools which are available free online. Most of them are image capturing and video capturing tools. The best among those is Snagit. This is not a freeware tool but you can actually try the trial version.
https://www.techsmith.com/screen-capture.html?gclid=CPG-2vq4v7ICFRHMzAodxH8Atg
Please see the link for windows download.
The tool is available in other sites also which can be downloaded freely but it can be a trial version or manipulated version which is illegal. Please let me know if you need any more help on the same.
Samuel
If you do a search on the Google you’ll find many of those software. Some are free and some are commercial products. There are many good software’s available for free so you don’t need to spend any money on buying them.
CAMSTUDIO is the best free screen capture software I have used. It will provide you screen capture feature and in add-in voice recording as well. You can download the software from below link. I have also provided you with a link to see some best rated commercial screen capture tools.
 http://camstudio.org/
http://www.toptenreviews.com/software/utilities/best-screen-capture-software/
Thank you friends, for sharing your knowledge with me. Gallon Samuel, I especially thank you for giving me vital information. The link that you provided is superb and this software is really awesome. With this, I can capture anything on my screen and with the ultimate screen capture, too.
Also, I can quickly create images and videos to give feedback, solve a problem, or show off something cool. Thanks again, Gallon Samuel, for sharing your opinion. I also think that your solution is the best solution.
