Hi guys. I don't know if I have a damaged or corrupted USB Flash Drive. I have the 8 GB Apacer AH223 USB 2.0 Flash Drive and my desktop won't detect it. I'm looking for a software to virtually look what the damaged part is in the USB. Is there a virtual disassemble Apacer USB software that I could use? Thanks guys.
Is there a virtual disassemble Apacer USB software?
Hello Donna,
There are many reasons why your desktop will not detect it. I recommend you get a strong and updated antivirus. And scan your computer. Then connect your USB drive, go to the my computer and check if you see it. If you see it right click on it an scan for viruses. Then try opening. If this way doesn’t go you can try any of the repair utilities on this site http://3d2f.com/tags/apacer/data/usb/flash/disk/utility/ . If it doesn’t go still then i am sorry the USB is bad.
