Is there visa runtime for labview 2010 for 64-bit?
I have used the LabVIEW Application Builder to make the exe files. The operating system is 32-bit Windows. But now I need to execute the visa runtime for labview 2010 in 64-bit system. I have checked that labview 2010 is only for 32-bit system. Will this run-time engine work in 64-bit? Or where can I take the one which will work?
Best Answer by James V Rose
Answered By 35 points N/A #132522
Hello Anthony
There is a 64 bit version of LabVIEW.
The 32 bit version will still work on a 64 bit Operating System. Some functionalities geared towards the 64 bit architecture will not work though but more or less the program will be 90% at your disposal.
Sincerely,
Luz M Terry
Answered By 50 points N/A #132523
Hello Cisneros,
The Run-TIme engine allows your browser to display Vls that are embedded in web pages. If you try to attempt to view a Vl through a browser and you were directed to this site by your web browser the Vl will display correctly after installing the respective Run-Time engine. 32 bit for 32 bit browsers and 64 bit for 64 bit browsers. Click the link below to download run time engine.
http://www.ni.com/en-us/shop/labview/download.html
