Hi everyone,
I installed iDVD for Mac OS X to burn a few files as a backup. Whenever I try to burn a disc am faced with the error shown below. Any ideas?
Error during rendering/encoding
There was an error during rendering/encoding of the menus/slideshows. The burning process has been canceled.
There was an error during rendering encoding of the menus
Hello Donald,
Good Day!
To resolve your problem quickly kindly follow this process:
To start new projects just add one element at a time. First are title and then the menu audio track. Then the first menu item which is the movie, then the next, etc.
If you are done adding each item try this File > Save as Disk Image and make sure it got past through the “Process Menu” item and into “Process Movies”. Then cancel and add the next item.
Hope it may help you.
Quinn Poon
