Hello experts,
Is there a way to convert lpt to pdf? There are some converters that are just limited to only one or two format. What I need is a converter that can adjust from the user’s need. Just name and suggest the best software converter you ever tried.
Is there a way to convert lpt to PDF?
Hi Kristin Runaldou, I searched some solution that may help your problem.
You can try this easy to use online converter which converts audio, video, image, document, ebook, archive, and even generates Hash.
Click on this link:
https://www.online-convert.com/
1. Click on Document converter, choose convert to PDF then click Go.
2. After clicking Go, click choose file or you may enter the URL of the file.
3.Click on Convert, wait for the converting process to finish.
When the download is finished it will be automatically downloaded in your PC. Just click it and there you have it.
Hope this information helps.
Hi You wanted some tool that shall help you to bring the solution of converting various files. You can try this online tool in that may help in all kinds of conversion: https://www.zamzar.com/ Upload the file, select the file type, insert your e-mail, click on convert. Easy process. Thanks.
You can print PDF file from any software you are using that allow print command by using a simple software called PDF creator.
To download PDF creator use link:
http://download.cnet.com/PDFCreator/3000-18497_4-10558866.html
After installing this software whenever you press Ctrl+P or you open print dialog box a new printer is there with the name PDF creator. Select it and click on print it will automatically print the document, page etc. in PDF file without any trouble.
