Is there a way to transfer an Excel file to cloud
 Is there a way to transfer an Excel file to cloud and have another user from a separate area and IP address update this file? What are the regulations in going about this process i.e. in terms of file size and the licensing charge for Microsoft 2007?
Best Answer by Allen Kenneth
Answered By 0 points N/A #126889
There is a way to transfer an Excel file or any other file format into cloud. Microsoft introduces application Microsoft Codename
"Data Transfer" with the help of you can transfer any type data to SQL Azure or Windows Azure Blob storage.
It is a simple method to do it—
1>First import an Excel file into a Web Application "SQL Azure"
2> Then, upload data into Windows Azure blob storage Account.
You can get a free trial from this link:
You can sign up and get a free trial.
Answered By 20 points N/A #126890
Hello Dasta,
To transfer an Excel workbook or any other file format into a cloud, Microsoft cloud computing platform called "Windows Azure" can be used. Its' data management feature includes the SQL database known as "SQL Azure". With this web application you can transfer your worksheet/workbook successfully in to a cloud using Microsoft SQL Server.
First install the SQL Azure, step by step installation guide is given on this site.
Just import the excel file in to SQL Azure and upload data into storage account.
Hope this will be helpful.
