Hello fellows,
Is there a way to upgrade outlook 2002 to 2010? There are some people who love to upgrade software and other important applications such as Microsoft packages. If it is possible to upgrade software like outlook, please do let me know and share those ideas with me.
Martha Nelson
Hi Martha, Yes its possible to upgrade your office suite/ outlook 2002 to 2010.. all you have to do is to have the office 2010 installer, then execute it to your computer where outlook 2002 installed. During the installation it is automatically imports and setup-up all the possible upgrade. I hope this can help you.
Thank you.
Hi Martha,
There are different ways to upgrade from Outlook 2002 to 2010. First you need to have a latest version of Outlook 2010.
Install Outlook 2010 and create a new Outlook profile and then it will create the new PST file.
Open the old PST file and then copy the contents to the new PST file.
Another option is to import the old PST files, but it is not recommended.
Thanks!
