I just want a software that allows you to reset passwords from the database which you can encrypt the keys for a moment of time. And to discover all the password keys in a specific database , will a vt helps it? Give me some solution thanks.
Is there a way vt can reset passwords in database?
Hi
There is no such type of software that can reset all database passwords. Because every database uses their different key logs and stored in a different – different locations. So it is not possible to reset database password by using a unique software. You have to go through every database password reset procedures to reset password for respective database.
Hi Halleleilani,
Resetting passwords should be done individually and on their corresponding websites and accounts. This is to protect your account securIty. To easily reset a password:
1. Click the Forgot Password option upon logging.
2. You will be prompted to enter an email address associated with the account.
3. Log on to your email and follow the instructions sent to you.
Hope this helps.
Murakami Wyatt
