Is there a wireless Cam recorder source android app?
Hi guys.
Is there a way to view and control my IP recorder camera and DVR remotely using Android?
I have a 4 GB Huawei Ascend G500 that has the MTK 6577 chipset, Dual-core 1 GHz Cortex-A9 CPU and Android OS Ice Cream Sandwich.
I need help in cam recorder source Android.
Best Answer by Jose K Vincent
Answered By 60 points N/A #171864
Hi Richard,
The answer of your question is Yes, you have some ways to control your IP cam and DVR remotely from android with some application.
There is an application named IP Cam Viewer Pro, which gives you opportunity to do the same.
The application is supported in your phone as configuration you mentioned.
I am sharing you the Google play link of the application :
Hope this will help.
Answered By 20 points N/A #171865
Good day. In order for you to remotely control and view your IP camera, traffic cameras, network video recorder, and CCTV or webcam, you can download an IP cam viewer lite.
It is awarded as the best software last 2011. It is upgraded in two way audio support in some cameras and also upgraded for record mode.
