TherMacam explorer for window 7 free download
      I have downloaded Thermacam explorer for window 7, but it does not work. It says some registry file error. It says make some registry file first and then install it. If someone knows how to install Thermacam explorer on window 7 then tell me or if he/she has any file related to registry that can help me then please tell me.
Best Answer by Nicke Baker
Answered By 0 points N/A #133256
Hello Lark,
Did you download a trusted version of Themacam explorer, and also did you download it from a trusted site? It seems like the app that you are trying to install is not trusted and as a result the fake registry issue that you are getting. You will therefore need to go back online, probably from the developers site and then download the software again.
Nicke
Answered By 10 points N/A #133257
First make sure you are login as administrator and then install the program and make sure you full fill all the requirements for the program and you have a valid copy of software.
Smith Thompson
