Kristi
50 points
Posted on - 04/16/2012
I am planning to build my own computer system.
One thing I need to consider is to buy good chassis.
I found out that Thermaltake Level 10 GT Battle Edition Chassis unveiled.
I already bought power supply.
I want to know, what size power supply does the computer case have? Â
Thermaltake offers a new version of its box Level 10 GT. it is the Level 10 GT Battle Edition. Using exactly the same characteristics as its predecessors, this new version is just different in terms of aesthetics. Thus, as the name suggests, the Level 10 Gt Battle Edition features an army green color decorated with a print style military.
In addition to this military design, the Level 10 GT Battle Edition is no different than previous versions.
Thus, we have the same available space that is to say four by 5.25 inches, 3.5 inches and one in five in 2.5 and 3.5-inch Hot Swap compatible.
It is the same for the cooling system with five fans, including three 200 mm on the front, top and side, a 14-mm rear and another of 120 mm as an option on the bottom. In terms of connectivity, we always have two USB 3.0 ports, four USB 2.0 ports, one eSATA port and audio input / output and microphone headset.
For the power supply it is a Standard PS2 PSU.
You can have all the technical specification in the URL:Â
Thank you.
