These Steps Will Increase Computer Performance! And Reduce Lag In Your PC
Hello guys, recently I have been facing performance issues with my computer. Can anyone tell me how to increase computer performance?
You can increase computer performance in the following ways:-
1. Uninstall any unused programs that you do not use. Uninstalling any useless programs will increase the space inside your system and also will improve your performance of the system, as some of these programs take up space inside your memory and load up during the start-up of the system. Thus slowing down your computer and decreasing the performance of your system.
2. Also, keep your drivers and programs up to date. Keeping them up to date not only improves the compatibility of the drivers and removes bugs and errors, but it is also optimized to increase the overall performance of the system.
3. Clean up your system temp and prefetch files. By doing so, it will not only free up space in the system, but it will also boost performance as these files are like cached data inside the mobile that gets created over the period when you use a program or system. So deleting it will not hurt your operating system. Instead, it will work in favor of it and will eventually boost the performance of it.
