Thin client SMS Server or thick client, which is better?
Which is better thin client SMS server or thick client SMS server? What are the advantages and disadvantages of each server?
Hey Mox646,
Thin clients are following advantages and disadvantages:
· They tend to display changes in information something like, News.
· They have changeable data with simple and variable display requirements.
· Places, where you need fast connections and some sort of small chunks of information you want to find really quickly.
· Thin clients also require a high performance level for bulk processing which is also a big disadvantage.
· The security operator can be accessed unauthorized which is the very great threat in this regard.
Thick clients are following advantages and disadvantages:
· They tend to show something which is repeatedly used by the user. In this regard caching can reduce the entry and give faster results.
· It’s an intelligent data delivery response system.
· Actual and real security is guaranteed in this client.
· The thick client is responsible for processes which occur on the client side.
So, depending upon the requirements and other factors both clients can be good or bad for a system.
Notifications
