Hello
I have recently been trying to update thinkvantage system to easily manage my wired and wireless network settings. When I try to update my drivers, I get the following error message everytime:
Sorry for the language. Actually it says:
During assembly of user data an error occurred
I don’t know what to do. I tried finding the solution but I failed. Can anyone please suggest how to fix the issue? Waiting to hear from you soon.
Kindest regards
Thinkvantage system error – during assembly of user data an error occurred
This is a very common issue with the applications that try to manually change the values of some variables for multiple users.
The error says,
Occurred while trying to manually change the value of some variables for the user!
In other words the variable did not give access right for read write operation and it tried to change the value.
The error can be caused because there are multiple users on your PC.
If that is not the case then there is a bug in the software! Please re-download it from another source and try to reinstall it.This will solve the issue!
Hope you got your answer! 🙂
It looks like you are using Lenovo Laptop. It does look like that Lenovo system updater is broken and there is some problem as it is exhibiting terrible amount of CPU coil. The best way to load the drivers like video, touchpad etc is through the system updater. It looks like you are having problem with loading these drivers. You need to make sure that you get the system updater work properly. You should consult an hardware expert to get this in right shape.
