Bob T Smith
35 points
Posted on - 05/30/2013
The documentation for software ag webMethods OneData says it can be used with third party reporting tools. Can you provide me with some examples of such reporting tools that can be used with it?
Third party reporting tools with software ag webMethods OneData?
Hi Bob,
Upon checking the documentation it does not specify what reporting tool it supports it only says any reporting tools. So I have here a list of reporting tools you can check most are open source so you can test them first:
1. Eclipse BIRT Project
2. GNU Enterprise
3. JapserReports
4. LibreOffice Base
5. OpenOffice Base
6. Pentaho
7. SpagoBI
The most popular third party reporting tool right now is Conga by AppExtremes. Their website can be found here. They support Word, Excel, Powerpoint and PDF formats. It is consistently in the top ten list of most downloaded applications in the AppExchange and all user feedback and customer satisfaction indicates that it is top notch.
