Third-Party Software for Listing All my Missing Hardware
I have to reinstall my Windows 7 after running software which I got from the web that caused various problems and errors on my system. When I checked on the Device Manager, I am missing some of the drivers but my task manager did not supply any information needed to distinguish the hardware. Is there any third-party software that I can use and will provide me all the information needed? Help please. Thank you.
Answered By 0 points N/A #120601
Hi Georgina, Check your missing drivers and go to Hardware Manufacturer's Website to check for Updated Driver Software for your Computer that is the best thing that you can do but if you want to use a Third Party Software then there's a lot to choose from. I am using Driver Scanner from Uniblue.com to help me from other Driver Software that I can't find from the web. You can download this Software from this link http://www.uniblue.com/product/pc/driverscanner/ . This software will automatically search all of your missing drivers. You can use this but you need a Serial key to enable the features. I hope this will help.
