I have to use about four to five browsers at a time for my job and all the browsers has to be quick. So far all the browsers were working properly, however recently the thunder bird browsers has gotten slow which is affecting my work greatly.
If this problem is not solved quickly then there will be some serious problem.
Vincd Milano
Thunder bird browser has gotten slow
Dear Vince Milano,your thunder bird browser may slow for various reasons. For faster running of a program requires a good amount of RAM memory or virtual memory. Your computer might have enough RAM or virtual memory but you have told that you run 4 to 5 browser at a time. Can you imagine all the browser use up the virtual memory as well as thunder bird too.
So,please try to run least program at a time and again uninstall some program that are not important. There is another reason that extensions is used by thunder bird and this cause  slow loading of the pages. You can speed up thunder bird disabling the extensions. Extensions may be disabled on thunder bird simply running it in safe mode.
I advise you to be certain that you possess sufficient free physical memory so that applications do not slow down by continuously being stimulated to/from the swap file.
Swapping can be decreased by reducing the quantity of running applications, and programs in your system tray.
