roquib007
70 points
Posted on - 06/23/2011
I wanted to use thunderbird as my default desktop mail application,i installed the software successfully and the problem is when i put my mail in the new account list it is not working.
It says something about smtp or tcp ip port,i don't understand what it is and how to configure this.
Pines
TCP/IP Error on setting up Thunderbird
Hi Roquib007,
Let me go straight to the point. In order to fix this problem, you would need to contact your Internet Service Provider (ISP) or email provider. You need to get from them the configuration, they use for email security and outgoing authentication or their SMTP settings.
But to help you out further, once you have the information needed, please follow the following steps:
Open Thunderbird and go to Tools>Account Settings. On the left side or at the bottom of the list, click on SMTP or Outgoing Server.
Click on Edit and this should open up the SMTP Server box.
Check that the Server Name and User Name fields are populated correctly.
Click OK
Note: The standard SMTP ports are as follows. But if you’re still having issues, please check with your ISP or email provider as they may be using a different configuration.
No security: Port 25 or 587
TLS: Port 25 or 587
SSL: Port 465
If this still doesn’t work, go back to the SMTP Server box and see if SSL is checked. If it’s not, check it (which means that your server requires a secure connection).
Hope this helps you out.
