I am having some time and location related problem while connected to internet.
Each time I connect my pc to internet it changes my pc time and location. which cause in some serious problem for.
What should I do to solve this problem.
I cannot afford to reset the time each time I turn on the pc.
Please someone give some suggestion.
Spencer Reynoso
Time and location changes while connected to internet
Automatic time updates may make your problem and it seems that you have the same problem that automatic time zone update is turned on on your PC. So you may get escape from automatic time changing by setting it to not automatic updates. Depending on your deep problem several methods may solve the problem.
Please follow this simple method if it work:Click on your clock and go to time and date setting. Then click on Internet time,then unmark the synchronize box by clicking on change setting.
Second task you can do:type services.msc on your search box from start menu. Find out Windows time to disable.
Third method:Set up time and setup time zone.
