Time & Date Setting Error
Hi mates,
I downloaded and installed Linux Mint 9.0 XFCE.
While changing the time and date in "Time and Date Settings," I clicked on the "hour" arrow, I got an error message that read:
Error:
The configuration could not be saved.
An unknown error occurred.
Please advice as to what should I do, in order to sort out this error.
Thanks in advance.
Answered By 10 points N/A #83883
There are several ways to set time and date in Linux.
If you are not able do it in graphical interface try using a command.
There are different commands in Linux to set time and date.
I will explain all and you can choose one for your choice.
Use this to change your time and date
date –set="STRING"
for example
  • # date –set="2 OCT 2006 18:00:00"
Ifyou don’t like it in this way you can choose this as well
  • # date +%Y%m%d -s "20081128"
You can also choose this if want to change the time
  • # date +%T -s "10:13:13"
These are several commands to display time and date in different format.
You can choose of your choice.
