Limit Circumvent that allows automatic back up
Seeking to secure my computer data, I plugged my Mac Mini in the local network to perform an automatic backup Time Machine to all of my Mac and PC and i am confused.
Apple's website states that automatically Time Machine backups of all existing Mac on the network. Is it possible to circumvent this limit?
Thank you!
Answered By 0 points N/A #79622
Hi John,
The problem you discussed is about limiting circumvent of a time machine which is a feature allowing automatic backups. The limit of the automatic backups is scheduled and programmed to already preset time of 1 hour and changing or altering the interval value will not going to affect it.
But with that in some cases there are some exceptions to that as if your operating system is updated and installed with the install option then you can alter and choose the time between 1 to 12 hours for that you need to run a demon which will also enables for you the feature of automatic startup and login.
