Timed out while connecting to DirectPlay lobby
Hi there,
I have this error from my new game that I have installed on my PC. Total Annihilation is giving me this error and I don’t know what it means. I have this error when I want to play online. I have a high speed Internet connection and this should not be a problem. Can anyone help me to fix this error ? What could be the problem.
Thank you !
Total Annihilation
Timed out while connecting to DirectPlay lobby!
OK
Answered By 0 points N/A #175223
Hello There,
Set up port relationship in Winroute.
You may refer their official website for more help.
Basically, you need to do a mapping of range of TCP/UDP ports
It may look like this
port map 1:
Protocol: TCP
Listen IP: <Unspecified>
Listen Port: port range 2300 to 2400
Destination: Your internal IP (192.168.x.x)
Destination port: 2300 to 2400* (*=greyed out)
Allow access only from: should not be checked
port map 2:
Protocol: UDP
Listen Port: port range 28800 to 28912
Destination port: 28800 to 28912* (*=greyed out)
Hope this helps
