Timer Code for Visual Basic 6.0
Good day guys!
Im creating a program right now using Visual Basic 6.0.. My software needs to have a Count down timer..
What is the code for Count Down Timer for Visual Basic 6.0..?
Anyone care to help..?
Good day guys!
Good day to you too, hope your project will go best. I will try to help you and explain you what you want. In order to enter count down timer, you need to decide the format first. Either you need hour, minute or second sequence or any other. Go to this link
http://www.vb-helper.com/howto_countdown_timer.html and you will get the complete code. Hope this will be helpful and you can complete your project by time. This link contain different codes and you can use according to your need. Similarly also try the codes for other things, but count down timer is pretty good option.
If you want to work using the Visual Basic then you need code in every steps. If you want some code then i am sending you a link. That link will help you very much. Have a look and take what you want. You can learn many things from there. http://forum.codecall.net/topic/38171-a-simple-timer/. Try this and solve your problem.
